Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > No Choice..... TV is Kiddie Corner in...
Author Thread: No Choice..... TV is Kiddie Corner in Room.....
Username: Nickydiction
What is the best setup for a kiddie corner television? Right now I have the left and right speakers about 2 feet or so above the top of the television, hung on each side wall. The sattelites are in corners opposite to each other.
The room also has a vaulted cieling. Here is a rough sketch. There is no other way to place furniture due to a fireplace and sliders in this room as well.
X= Speaker
O= Seating
TV= TV Set
text/plainSketch
sketch.txt (0.1 k)
Username: Audioking
Hi Nick, your arrangment is definatly not ideal however you may be able to attain satisfactory results with the proper setting of your processors volume and delay.
I would recommend more volume and less delay.
Hope this helps.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > No Choice..... TV is Kiddie Corner in... [ « Previous ] [ Next » ]
