Thread: Dumb Question For the Experts Here |
New member Username: Simmons3333
Federal Way,
WA
Post Number: 1 Registered: Apr-05
| Posted on Monday, April 18, 2005 - 05:59 pm: |
I have a JVC XV-D723 DVD player with separate outs for Main/Rear/Center/Sub. I am running one amp for the main, another for the rear and right now a receiver for the center channel (into CD left). I am only using the left side for the center channel. Here is the question...could I run the center on the right channel and the sub on the left? I am just curious as how it would drive the different channels or would it not work correctly???? The sub is a passive Polk RM3000. |
Silver Member Username: Dmwiley
Post Number: 462 Registered: Feb-05
| Posted on Monday, April 18, 2005 - 06:51 pm: |
David, why are you doing this? |
Federal Way,
WA
Post Number: 2 Registered: Apr-05
| Posted on Monday, April 18, 2005 - 08:02 pm: |
So I can have my sub and eat it too. Just kidding. I am running the separate amp set up as I have a hearing disability and a normal 5.1 receiver/amp can never get the center channel loud enough for me to hear properly. I can turn down the main, sub and rear speakers, but then I lose the enjoyment of the 5.1 surround. With separate amps, I can get the center channel to the volume I need. I was just wondering if I could run the sub out to one side of the CD/AUX in on the receiver and the Center to the other side of the CD/AUX in and control the volume of both at the same time. This is just a temporary fix until I get my other amp in... Thanks David
Richard A Unregistered guest |
| Posted on Tuesday, April 19, 2005 - 10:06 am: |
Don't see why not. The centre will (for example) be going into the left imput and out of the left output, and the sub will be taking the right hand input / output? You'd then use the balance on the reciever to alter the volume between the two? You might find that its fairly difficult to get a happy medium with the bass and treble though.. becuase you'd need to have the same settings for both the centre channel and the sub. I suppose a compromise between really deep bass and a natural sounding centre would be the main problem. Give it a try, but check on the temperature of the amp when playing a DVD / Music. Let me know how it goes. |
