Thread: Optical cable...can you help please |
| Posted on Monday, April 18, 2005 - 04:10 pm: |
I connected the optical cable from my DVD player to the receiver. I have unclear sound with noise,the noise it can damage the speakers, but after(15 min) the sound start to be clear. what the problem |
Bronze Member Username: Max190
Maryland Heights,
Missouri
US
Post Number: 20 Registered: Apr-05
| Posted on Monday, April 18, 2005 - 05:23 pm: |
Check the setup menu in your DVD player. You may have to set digital out to yes. Also look at dolby digital out choices. |
Silver Member Username: Dmwiley
Post Number: 463 Registered: Feb-05
| Posted on Monday, April 18, 2005 - 06:53 pm: |
Also check set up of receiver and make certain it is compatible with DVD output. |
New member Username: Tallman
Post Number: 1 Registered: Apr-05
| Posted on Wednesday, April 20, 2005 - 10:17 am: |
i check all..can be it problem from insid the recevir(electric problem) |
New member Username: Victimofthe211
Post Number: 3 Registered: Apr-05
| Posted on Wednesday, April 20, 2005 - 02:59 pm: |
are you using the cable for surround? because if so then maybe there is some faulty speaker settings or you could try another cable to see if thats the problem. if neither of those work, then it could be a problem with the processor inside the reciever. |
