Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Instructions for cat dvd htc-2002
Author Thread: Instructions for cat dvd htc-2002
Username: Brianlawrence
Hi
I have lost my instructions of what wires go where into the back of the dvd. I know what all the wires are eg front back left or right etc. However, the back of the DVD hasn't got the connections marked. DO YOU HAVE A COPY OF THE INSTRUCTIONS GIVING THIS INFO PLEASE HELP.
Username: Project6
Post Number: 302
that is very odd, no markings?
It should be standard, though, the RCAs are usually color coded. Yellow=composite video out, red next to white= right & left audio out (analog), orange=coaxial digital output, then there is that weird looking square=optical output or Toslink, then there's another grouping of dark red, blue and green right next to each other = component video output. Just match it all up to your receiver or TV inputs and you are there.
cheers
no such luck. they are all cable connections + and -
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Instructions for cat dvd htc-2002 [ « Previous ] [ Next » ]
