Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 14, 2005 > Caring for your speakers
Author Thread: Caring for your speakers
Username: Tymetwister
What do people recommend for upkeep and maintanance for your home speakers and receivers? Are there any recommended cleaning products or methods out there?
Username: Paul_ohstbucks
Post Number: 501
Absolutely nothing.....
Except for the typical dusting your components with a damp cloth, there is no maintenance necessary for electronics or speakers.
Every 10 years or so, you might consider snipping and restripping your speaker wire connections to refresh the connection, but that's about it.
Username: Max190
Maryland Heights, Missouri
US
Post Number: 10
Chris,
A light dusting an plenty of ventilation will keep your AVR happy.
About every 4 months I apply lemon oil to my speakers, plus I check and tighten all the screws that are used to mount the drivers.
thanks guys... I actually tried these anti-static cleaning wipes for my receiver and they seemed to clean it well (removed fingerprints and oil from touching). Came out looking brand new. Wal-Mart sells them for 4.99, manufacturer is nice'n clean.
Post Number: 516
So now stores are trying to peddle anti-static audiophile receiver wipes??...........heheh
Geez......What's this world coming to?? We're only talking about dusting, right???
Any damp handtowel is all you need!! Dampen it with plain H2O for best results........Heh.
cost...........$.00, and the towel is machine washable.
One catch though.......
When you wash the hand towel after dusting, be sure to buy the Audiophonics agent-X stereo demagnetizing detergent before re-using said hand towel on bare skin. Otherwise, a nasty 7.1 home theater rash may develop and irritate your skin if the hand towel is not properly un-stereoized.
anony
Pretty much a no-brainer here but definately keep your speakers out of sunlight. Especially if they don't have grille covers.
Sunlight will quickly deteriorate most rubber and foam surrounds on speaker drivers.
Keep em' clean
Don't poke the speakers with sharp objects, you may damage the cone.
Don't drop the speakers from first (or higher) floor windows. This may cause the cabinets to break.
Don't cover your speakers in bird seed, then release 20 parrots into your cinema room. This may cause the speakers to become soiled.
Username: Joe_c
Oakwood, Ga
Post Number: 136
also don't go to the bathroom on your speakers as this may not only damage them but there is a chance of electric shock with a number one.
Username: Santora
Post Number: 9
And NEVER ever mount them in the shower
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 14, 2005 > Caring for your speakers [ « Previous ] [ Next » ]
