Thread: Help needed for Xbox setup with receiver |
New member Username: Jon61277
Post Number: 3 Registered: Apr-05
| Posted on Thursday, April 07, 2005 - 12:35 pm: |
I've got several questions here about Xbox and my surround sound receiver. I've seen there are 2 AV packs you can buy for Xbox: the Advanced AV pack, and the HDTV AV pack. It appears that with the Advanced, you can get a digital audio output, and a S-Video output; with the HDTV you can get digital audio output and component video output. Currently I do not have HDTV, but I do have a TV with 1 component input (currently used for DVD), and 1 S-Video input (currently used for satellite). I could see myself upgrading to an HDTV in the next 1-3 yrs, depending on how quickly prices drop. Also, my AV receiver has 2 digital optical inputs, both are being used for DVD and satellite. Here are my questions: 1. What do I need to buy to be able to also plug the Xbox digital optical into my receiver since I only have 2 slots and both are in use now? 2. Is there anything I can do right now to run both the Xbox and DVD component output into the 1 slot available on my TV? If there is anything available, how much does that cost? Or I am better off just using S-Video for the XBox video output to the TV? Any advice is much appreciated! |
Bronze Member Username: Scotty2hotty
Chicago,
IL
Post Number: 57 Registered: Nov-04
| Posted on Thursday, April 07, 2005 - 05:09 pm: |
1. Something like this: http://www.connectxpress.com/product.asp?cat_id=1206&sku=27027 2. Not sure... |
Silver Member Username: Joe_c
Oakwood,
Ga
Post Number: 103 Registered: Mar-05
| Posted on Thursday, April 07, 2005 - 07:22 pm: |
you might wanna try this, I know its more money but the problem with a splitter is that some units feed a digital signal when they are idle or even off so a splitter wouldn't work. I have used one of these and was very pleased with the results, plus it takes care of all of your problems. |
Oakwood,
Ga
Post Number: 104 Registered: Mar-05
| Posted on Thursday, April 07, 2005 - 07:24 pm: |
http://www.digitalconnection.com/products/video/1154a.asp sorry forgot to place link |
New member Username: Santora
Post Number: 10 Registered: Jan-05
| Posted on Sunday, April 24, 2005 - 03:06 pm: |
From what I've seen the optical and component are about equal. Given the fact you are probably moving around your XBOX a lot optical would NOT be my first choice anyway- much more fragile. Additionally the vast majority of xbox games aren't really taking advantage of the technology the same way HDTV broadcasts are- I used a DVI connection at one point for my xbox and couldn't notice a difference on anything I played. On the other hand the difference between optical or component and RCA is pretty big. Anytime you add another piece of equipment into the input/output loop you can change the quality and it's unpredictable. Example- I have a 20 year old cable TV splitter made by Fischer that works great and a brand new high end one with gold plated blah blah blah and I returned it the same day because the picture looked horrible. Go with component. |
