Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Speakers to go with Onkyo TX-SR602
Author Thread: Speakers to go with Onkyo TX-SR602
Username: Marcio
Post Number: 12
I'm really confused about the best method for connecting a sub to a receiver.
From what I have read so far, we should never use 2 crossovers at the same time: the receiver's and the sub's.
If this is true, the best connection, supposing a receiver has bass management (i.e. an adjustable crossover), would always be the LFE. Am I right ?
So, why do most subs have speaker level connections and some brands, like Polk, do recommend this method of hookup ? Is it because old receivers did not feature adjustable internal crossovers ?
I need to buy a sub for my Onkyo TX-SR602 and I'm selecting only models with a LFE input, following my logic.
I someone can help, please write. I would appreciate some really sound advice on this.
Thanks !
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Speakers to go with Onkyo TX-SR602 [ « Previous ] [ Next » ]
