Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Sub with analog
Author Thread: Sub with analog
jp1074
My CD is an analog signal back to my Marantz 5400. Is there a way to get the sub to play while listening to the CD player. DTS and Dolby only send a signal to the sub if a digital signal is used. Also when listening to just stereo music the sub does not come into play.
Prof. Englebert
Yes, connect the modulating out to the vistration in on the back of the amp. set the high-pass to +50hz and the low to >.756mhz. Use the 15gauge cable supplied in the packet and wire the amp to the sub inputs and connect them with the flange gubulator.. hey presto, job done.
Username: Jp68stang
wow .... thanks Prof., last night I hooked it up as you said and it worked beautiful.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Sub with analog [ « Previous ] [ Next » ]
