Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Rear Surround Options
Author Thread: Rear Surround Options
Username: Deeman
My room measures 23'X 13'4" and I don't have ANY area on the rear side walls to mount any surround speakers. I am going to have PSB Image series speakers for the fronts...what are my best options for speaker placement and kind of speak for the backwall? I'm considering the Image S50 Bipolar surround speakers to be mounted on the back wall as per home theater rep in local area. See http://www.psbspeakers.com/s/ImageSeries.html
Advice and opinions appreciated!
Username: Project6
Post Number: 2864
Nice speakers, should compliment the rest of your system nicely. Try them out and if you like them, keep them. You really can't tell how speakers will sound in you own particular room. But it should work out nicely.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Rear Surround Options [ « Previous ] [ Next » ]
