Thread: Dolby ac-3 |
Bronze Member Username: Jbecvar
Post Number: 28 Registered: Mar-05
| Posted on Saturday, March 26, 2005 - 05:32 am: |
I just purchased a laserdisc player that has the ac-3 output jack on it, but my receiver doesn't. I was wondering if I could hook up the ac-3 to the digital coax jack on my receiver if it would work. My laserdisc player is a pioneer cld 505, and my receiver is a pioneer vsx 1014. |
Aaron S Miller Unregistered guest |
| Posted on Saturday, March 26, 2005 - 02:22 pm: |
AC-3 = Dolby Digital... |
Post Number: 31 Registered: Mar-05
| Posted on Saturday, March 26, 2005 - 06:47 pm: |
tried it out, didn't work, is there a difference in the way the two are decoded? |
Silver Member Username: Dmwiley
Post Number: 274 Registered: Feb-05
| Posted on Saturday, March 26, 2005 - 09:36 pm: |
If you have properly connected the two and followed through with any set up requirements, it should work. Make certain that the laserdisc in question supports dolby digital. Many, perhaps even most, do not. |
Post Number: 32 Registered: Mar-05
| Posted on Sunday, March 27, 2005 - 01:13 am: |
so then i have to have the stereo outputs and the digital coax hooked up to make sure I get sound? I tried seeing if the ac-3 to digital worked with "armageddon", which was dolby digital.
Post Number: 283 Registered: Feb-05
| Posted on Sunday, March 27, 2005 - 10:09 am: |
In answer to your connection question, probably. But it depends on your receiver. Some will default to Pro Logic when a dolby digital signal is not present. Did you get sound from Armageddon? |
Post Number: 33 Registered: Mar-05
| Posted on Sunday, March 27, 2005 - 06:03 pm: |
Only when i hooked up to the composite inputs. Nothing came out when I had it hooked to the ac-3 terminal. |
Post Number: 291 Registered: Feb-05
| Posted on Sunday, March 27, 2005 - 07:14 pm: |
Josh, I'm sorry but I am baffled. Check the manuals on both components and make certain everything is properly connected and set up. Receiver may have some form of switch. Sorry I can't do more. But without access to the manuals or equipment, I'm shooting in the dark. |
Post Number: 34 Registered: Mar-05
| Posted on Sunday, March 27, 2005 - 07:57 pm: |
np, thanks for the help anyway |
