Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Looking for some Input
Author Thread: Looking for some Input
Username: Sonic1
I am loking at buying a entry level system and I am stuck between 3 systems. Can anyone give me a difinitive winner among these 3 systems
RBH CT.5.1
Klipsch Cinema 8
Infinity TSS-1100
Also what Amp am I going to need to power these systems?
Thanks for your input Ive looked at these systems so many times My head is spinning
Username: Project6
Post Number: 2823
I like the RBH CT series. Do you have a budget for the receiver?
Username: Sonic1
About $500 for the reciever
Username: Javmo200
Michigan
Post Number: 16
You can not go wrong with Klipsch either--Let me advice you that cutting corners on your power supply (receiver) will make a hughe differents on how your speaker will perform..
Username: Project6
Post Number: 2829
Take a look at the Harman Kardon AVR 235. Nice receiver with ample power supplies.
Username: Javmo200
Michigan
Post Number: 17
I agree with Berny--great stereo for the price well build power supply and it will complement your RBH or Klipsch very well.
Username: Sonic1
I just talked to a friend of mine who told me to get a Definitve Technologies Pro Cinema 80 set up.
I researched them and they seem to kick butt you guys know anything more about them.
Thanks for the info sofar it is helping me not make a $1500.00 mistake can't afford that!
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Looking for some Input [ « Previous ] [ Next » ]
