Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Samsung HD-941 DVD Player - Green Scr...
Author Thread: Samsung HD-941 DVD Player - Green Screen Problem
Username: Pacificasurfer
I have Samsung 46 inch DLP and Samsung HD-941 DVD player hooked up to the TV using HDMI for video and optical to my receiver for audio. When watching movies, a completely green screen flashes for a second a number of times throughout a movie. It never happens with cable. Any suggestions or anyone else encounter this problem?
Username: Dmwiley
Post Number: 140
Sean, this seems like a fairly common problem with that equipment. I can't tell you how to fix it (not sure Samsung can either). I think you should return the equipment (if it is still warranted) and consider another manufacturer.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Samsung HD-941 DVD Player - Green Scr... [ « Previous ] [ Next » ]
