Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > DVI 'Y' cable instead of an expensive...
Author Thread: DVI 'Y' cable instead of an expensive switch?
Username: Murraymcleod
I have a Mitsubishi 55" CRT Projection with a single DVI input. I'd like to connect a cable box and an upconverting DVD player to this TV via that DVI port without paying $200-300 for a DVI switch. Is there such a thing as a DVI 'Y' cable, or would that cause problems, even if only one of the input devices were on at a time? Thanks...
Username: Paul_ohstbucks
Post Number: 344
I have never seen them, but someone here might have the answer you're looking for.
You might want to reconsider the upconverting dvd players at this point in time. Their performance is at best, inconsistant. They tend to upconvert more 'grain' inperfections in the DVD source, than they do anything else. The problem isnt so much the player, but the DVD.
For now, I would recommend getting a quality set of component cables, and using those until HD players and discs hit the market in force. Trying to take a lowdef source, and upconverting it into something it isnt, hasnt worked very well from what I've seen. I considered doing exactly what you suggest when I upgraded to HD, but after researching the topic, decided against the upconverting DVD player.
Anybody else have comments on this?
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > DVI 'Y' cable instead of an expensive... [ « Previous ] [ Next » ]
