Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > HDMI is my only connection. Any sugge...
Author Thread: HDMI is my only connection. Any suggestions?
Username: Baydo
McKenna, WA
HELP! Is there a swith box available that has component and DVI inputs with a HDMI output?
I have naively hard wired my home theater room with HDMI only.
Username: Paul_ohstbucks
Post Number: 323
There is no need for a switchbox because you can buy a cable with DVI connector at one end, and HDMI at the other.
You can find DVI>HDMI cables easily on the web, or at a good electronics store.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > HDMI is my only connection. Any sugge... [ « Previous ] [ Next » ]
