Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Projection lamps
Author Thread: Projection lamps
Username: Martinup2020
i like to know if can buy lamp for infocus sp4805 worth 350$. last time clean it i noticed that lamp can be removed seperate from cartrige. my gut feeling is that we are paying for plastic cartrige for nothing. i like to know where i can purchase just the lamp thk you in advance.
Stephen-Jones
Try using a 70 cents 40w light bulb from Wal-mart. Should work a treat.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 11, 2005 > Projection lamps [ « Previous ] [ Next » ]
