Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through March 05, 2005 > Does it matter when you slpit the RCA...
Author Thread: Does it matter when you slpit the RCAs with a subwoofer
Username: Chrisu37
I have read that you should slit the signal at the subwoofer preout on the reciver giving you two signals to the subwoofer for the best performance. I was wondering if you could just come out with one rca cable off the reciever and then just split it just before the subwoofer. I have a long run through walls, so just want to use one wire.
Any input would be great
thanks
chris
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through March 05, 2005 > Does it matter when you slpit the RCA... [ « Previous ] [ Next » ]
