Thread: Understanding how to use 7.1 on sony strde897 |
New member Username: Allirroz
Post Number: 1 Registered: Feb-05
| Posted on Tuesday, February 22, 2005 - 02:07 pm: |
I just recently bought a Sony strde 897 7.1 . I can get all 7 speakers plus sub to play audio but the problem I am having is that on the panel indicator for the speakers which specifies which speakers are playing the boxes for SBL and SBR are present but missing is the SBL and SBR indicators inside its box. Hope I make sense! Would this have something to do with the DVDs i am playing or could this be a receiver set up issue. |
Silver Member Username: Usa2k4
Post Number: 117 Registered: Dec-04
| Posted on Tuesday, February 22, 2005 - 04:20 pm: |
The box tells you whether or not the speaker for that channel is enabled and the letter tells you whether or not the sound for that channel is being decoded. If you don't see the letters SBL & SBR inside their boxes and the AFD is set to Auto, it means the DVD being play doesn't have the surround back information. You can enable Surround Back 6.1 matrix for 5.1 encoded DD/DTS DVDs, though, and if you have 2 surround back speakers connected and enabled, you'll get matrix 7.1 surround sound. |
Post Number: 2 Registered: Feb-05
| Posted on Tuesday, February 22, 2005 - 09:42 pm: |
Thanks Kevin for the input. Is it safe to say that I will only see both box and letters lit when a DVD playing is encoded to playback at 7.1 surround? This 7.1 is all new to me am trying my best to take advantage of all options available. |
Post Number: 118 Registered: Dec-04
| Posted on Tuesday, February 22, 2005 - 10:07 pm: |
Box and Letter: Speaker is enabled and sound is decoded for that channel. Box only: Speaker is enabled but no sound is decoded for that channel. Letter only: Sound is decoded but no speaker is connected and/or enabled. There are no 7.1 DVD's available as of this time but you can enable surround back matrix to get 7.1 sound from 5.1 and 6.1 DVD's. If you see both the boxes and the letters for the surround back channels, it means you are having 7.1 surround sound. |
