Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Advice on mid-range amp upgrade
Author Thread: Advice on mid-range amp upgrade
Username: Twright_bmw
Hi,
I am in the process of upgrading my old amp (Yamaha rxv596) and wondered if anyone could reccomend which is the best of the following:-
Denon 3803
Pioneer vsx-ax3
Yamaha RXV1400
Many Thanks
Tim
Username: Elitefan1
Post Number: 236
What speakers will you be using this new unit with? I had the 3803 and hated it for it's very bright sound and incredible vocal sibilance.
Username: Xtremeht
Post Number: 17
I have the 3803 powering B&W speakers. Very nice unit with video conversion and a ton of other features.
Hi,
Have the following,
Front Tannoy Mx3, Centre Tannoy MxC, Sub B & W ASW675, Rears M & K K-4 .
I have just upgraded my rears (the M & K's) and would also appreciate advice on new front/centre speakers. I do not want to exceed $800 for the fronts and $500 for the centre. Please note I am more concerned with home cinema than hi-fi.
Many thanks.
Tim
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Advice on mid-range amp upgrade [ « Previous ] [ Next » ]
