Thread: Bright scenes distort image |
| Posted on Tuesday, February 22, 2005 - 05:14 am: |
specs - 5.1 speakers, fairly cheap new receiver (i'm on a budget), all analog cables w/ the one coaxial, running both dvd and vcr to receiver, then one video out receiver to tv, standard flat screen tv. problem - when watching movies such as x-men, sudden bright scenes (i.e. lightning, electricity, etc.) will cause the entire image to distort. best description: as if somebody was messing with horizontal adjustment in back of tv. it's as if the receiver detests brightness. i tested video straight from dvd to tv and it works fine, so i assume it's the receiver? but i'm wondering if a simple upgrade to s-video will help? anyone ever heard of this happening? i'm still under 30-day return for receiver if there's no fix. |
| Posted on Tuesday, February 22, 2005 - 05:54 am: |
mixed up terms - meant to say that all current cables are rca, save for one coaxial for dolby. after reading more threads - maybe best option (despite my problem) for best rca image quality is direct feed from dvd to tv. think i read that running video thru receiver is like forcing it to pass thru an uneccesary source? and to just use receiver for sound? |
Post Number: 2764 Registered: Dec-03
| Posted on Tuesday, February 22, 2005 - 07:17 am: |
Do you have component video inputs on your TV? If not, just use a direct s-video feed from your dvd player to TV. |
| Posted on Wednesday, February 23, 2005 - 06:12 am: |
i research everything else before buying, tho i didn't do that before buying this receiver. i'll fess up now and tell you that it's a klh r5100. (laugh it up) i've had the 5.1 speakers for almost a year and they're doing a fine job. so naturally i figured the same brand receiver would. and i'm on a budget, as mentioned before. i've read nothing but negative reviews on this model since buying. plus my own personal problem with it. i'm currently by-passing the receiver and running video straight from source(s) to tv. but the fact of the matter is that i shouldn't have to. i think i'm just going to return it and save money while i (re)search for something better. thanks anyway for trying to help. |
