Home > Message Board > Home Theater > Surround Sound > Archive through March 29, 2005 > Dolby dsp 360 to 5.1 hometheatre system
Author Thread: Dolby dsp 360 to 5.1 hometheatre system
audio newbie
i have a 5.1 home theatre system that will give full 5.1 output for dvd's. it also has an auxiliary input for vcr's, etc. i have acquired a dolby 360 dsp prologic converter. will this give prologic surround if i connect it between the vcr and the aux input on the 5.1 system?
Username: Usa2k4
Post Number: 106
Is it the Seinnheiser DSP 360?
audio newbie
yes it is. i forgot to mention that
Username: Usa2k4
Post Number: 108
As your system is a 5.1 HT system, I believe it also has a built-in Dolby Prologic/Prologic II decoder. It's better to use the receiver's Prologic decoder to decode Dolby Pro sound for better surround sound than you could get from the DSP 360. The DSP 360 gives you only virtual Dolby Pro surround sound from Dolby Pro encoded materials using a pair of headphones or stereo speakers.
audio newbie
thanks for that. i can't try it out at the minute, as the tv is currently in 'not working' mode.soon to be rectified tho'
Home > Message Board > Home Theater > Surround Sound > Archive through March 29, 2005 > Dolby dsp 360 to 5.1 hometheatre system [ « Previous ] [ Next » ]
