Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through March 05, 2005 > Help with set up please!!
Author Thread: Help with set up please!!
Username: Cpottr
Hello everyone, I hope this message finds you all well. I am completely lost and need help setting up my new entertainment system. I have purchased the following:
Sony grand wega 50 inch tv
Sony DVP ns975v dvd player
Yamaha Rx-v750 receiver
Cox dvr player
I have purchased a hdmi to hdmi cable to connect the dvd player to the tv. I have also purchased a toslink optical cable to connect the dvd player to the receiver. Is that the right way to do it? I also do not know what I need to connect the tv to the receiver. I want to run the sound from both the tv and the surround sound system. I am assuming that the Cox cable person will be able to hook up the dvr system and the hd cable, but one never knows what will happen. As I am totally clueless, I would appreciate any help that anyone can give me. Thanks
Christian
Username: Project6
Post Number: 2733
First, check your owner's manual and if you still have troubles go here.
http://forum.ecoustics.com/bbs/messages/3/113395.html
A lot of setup scenarios.
Username: Paul_ohstbucks
Post Number: 97
There are lots of different setup possibilities. The only suggestion I have is that you might consider using the highest quality connection(HDMI) for your HD signal where it will make a larger impact, and then use component cables to connect your 480p DVD player.
As for your setup possibilities, a lot will depend on Cox and what output options exist on their cable box.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through March 05, 2005 > Help with set up please!! [ « Previous ] [ Next » ]
