Thread: Yamaha Speakers. Honest opinion. |
Bronze Member Username: Vtdakotaguy
VT
United States
Post Number: 36 Registered: Oct-04
| Posted on Sunday, February 13, 2005 - 08:52 pm: |
What does anyone think about this Yamaha speaker package? Yamaha NS-BP4500. http://www.bestbuy.com/site/olspage.jsp?id=1083714059342&skuId=6665218&type=prod uct I know it's cheap, but I was looking for something to replace what I currently have. I have a small space right now. The front left, right and center speakers are Bose double cubes. The rear surrounds are cheap AIWA's that came in a really cheap AIWA system that I purchased for next to nothing. I know there is a lot of Bose bashing going on, but I would like an honest opinion. Should I stick with what I have until I need to upgrade or are the Yamahas a better bet? |
Bronze Member Username: Gavincumm
Post Number: 53 Registered: Feb-05
| Posted on Monday, February 14, 2005 - 11:15 am: |
if you want something that is truly QUALITY, and can afford something just a little more than that, take a look at the link below. These things truly sound remarkable for their size, and have a true 2-way design. http://www.av123.com/products_product.php?section=speakers&product=36.1 I don't think you will be totally happy with the Yamaha speakers, but the Rocket Tykes will more than satisfy you once they are broken in IMHO. gavin |
