Thread: TV - Satellite box, AUDIO conflict! |
New member Username: Boca
Post Number: 4 Registered: 01-2004
| Posted on Friday, February 13, 2004 - 11:59 pm: |
Hi everybody... Question, can I amplify my TV audio thru AV receiver to get better stereo or simulated surround. Problem is that outlet on my AV receiver is used for satellite box. So what is my option (if there is any) how should I run TV AUDIO out to where into A receiver??? I hope I was clear enough! Thanks
Bronze Member Username: Joe_s
Post Number: 23 Registered: 12-2003
| Posted on Saturday, February 14, 2004 - 04:03 pm: |
What exactly do you have for a receiver? How many inputs? Does the TV have an output or maybe you can hook your cable box to the receiver? Joe |
Post Number: 7 Registered: 01-2004
| Posted on Saturday, February 14, 2004 - 04:34 pm: |
It is satellite box hooked up to receiver TV/DBS out and it is only Audio/Video output for TV. Others are for: CD, DVD, VCR1, VCR2, TAPE, PHONO and one V.AUX. So is there any component that I mentioned above can get TV audio-out to be attached to receiver for amplification. TV has RCA audio in and out. I need to find where I can put TV audio-out to my receiver other then TV-in Thanks a lot Boca |
