Home > Message Board > Home Theater > Surround Sound > Archive through March 29, 2005 > Can I switch my speakers to diff posi...
Author Thread: Can I switch my speakers to diff positions
Username: Stevetracy
I have an RCA RT2370 HT system. Does anyone know if I can use my Center speaker as my Left Speaker and Vice-Versa without losing sound quality. I need to do this because the center and right speakers sit on my mantle and the left is on the window sill. I know this sounds strange...but I'd like the two speaker that look similar to be beside each other with the long narrow one on the other side. to sum it up...Is my left speaker basically the same inside as my center speaker?
Username: Mystro
Post Number: 24
Sure you can. There is NO wrong answere. If you cant hear a difference, go for it.
Me-is-angry-about-not-having-suround-sound
Thank you, some one with a rca model. i am getting one to and need to know what kind of cables to get for it up to my xbox and the white yellow and red connections on my tv. thanks. and will surround sound work with the three color out puts on my tv.
Home > Message Board > Home Theater > Surround Sound > Archive through March 29, 2005 > Can I switch my speakers to diff posi... [ « Previous ] [ Next » ]
