Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2005 > Wall Mounts for Klipsch RS-35s?
Author Thread: Wall Mounts for Klipsch RS-35s?
Username: Landlockedph
Dallas, TX
Post Number: 32
Has anybody had any experience with wall mounts for the Klipsch RS-35s (or RS-3s)? My mounting location for both side speakers (7.1) is too high and I need some way to angle them down toward the listening area.
I'm looking at Omnimount as one option. Their model 10.0 is supposed to be for speakers up to 10 lbs. The RS-35s are listed at 9.6 lbs. I would assume that Omnimount threw in some margin for error over their recommended weight? The threaded, steel shaft (with 1/4"-20 thread) should fit the Klipsch threaded mount.
However, Omnimount's recommendation for the RS-3s was to go with the model 20.0. Unfortunately, that shaft won't fit the Klipsch mount. Maybe the speaker plate will line up with the keyholes?
Any experience you've had (or alternate suggestions) would be appreciated.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2005 > Wall Mounts for Klipsch RS-35s? [ « Previous ] [ Next » ]
