Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through March 05, 2005 > I need help with my hook up
Author Thread: I need help with my hook up
Username: Plyrsn1
Ellensburg, Wa
Us
I have a dvd theatre system that i noticed i only have audio outs from the dvd player. I want to be able to listen to the system through my tv, I also have a cable box, can i do so, and how do I hook it up, or do I need more equipment?
First you would have to pay off your debts to get things working right. Need a new address to send the rest of your judgement?
Username: Dirtfarmer
Alberta
Post Number: 385
shaun garringer
i might have a few answer for you but not all
Use this link to go directly to the discussion:
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?3/113395
I need help with trying to hook up a dvd/vcr to a GE television set that only has one input; and that is for an atenna. The tv is 4 years old and does not have a/v on the front or the back. Is there an adapter or a slpitter I can get.
Alberta
Post Number: 391
NachoDrive
most likey you tv had a coaxail plug on back, and yes you can watch a dvd on aolder tv
you just need one small part
lol
a RF Modulator
it covert the the feed so a older t v can see it
connect a dvd to rf mod use the 3 rca a/v white red yellow cable, and then connect the rf mod to tv use a coaxial cable
easy as pie
for more info see my posting on this site
Message Board: Home Video: DVD Players: Connect older TV to DVD, VCR & Digital Cable Box using RF Modulator
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?2/16195
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through March 05, 2005 > I need help with my hook up [ « Previous ] [ Next » ]
