Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2005 > Large or Small speakers
Author Thread: Large or Small speakers
Username: Seanycash
I'm setting up a 5.1 surround system with 4 Paragigm Titans as the fronts and rears, one C 380 as the center and a ?10 as the sub.
The titans are two way speakers. Should they be set as small or large?
What is the difference?
Some may disagree, but in most cases, you want your speakers set up as "small", so the low frequencies will be redirected to your subwoofer, which should be much more capable of these bass frequencies.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2005 > Large or Small speakers [ « Previous ] [ Next » ]
