Thread: Help a newbie set up 5.1 to a DVD - prob easy answer please take a look |
Unregistered guest |
| Posted on Friday, January 21, 2005 - 10:25 am: |
First of all let me point out that i am a complete novice so apologies if you've already answered this question a hundred times before! I've just inherited a very cheap 5.1 home theatre system (NEUTAC S8513110) and i need to wire it up to my DVD (TECHNIKA dvd203), it seems to work like this: The 5 speakers & subwoofer connect by 3.5mm jack to a control box (that's the easy bit) - the control box then has 3 inputs (front, surround, CE/SW) each is 3.5mm jack size - I have 3 cables supplied each 3.5mm to 2 x RCA - the diagram in the manual shows all 3 cables connected to the 3 inputs on the control box with the other end of the 3 cables (6 x RCA) connected to the DVD player! - my problem is that the DVD player manual suggests that 5.1 systems should be connected to a single coaxial digital signal output................ ...My question is how does 6 x RCA go into 1 X coaxial?? Thanks for your help in advance. |
| Posted on Friday, January 21, 2005 - 11:23 am: |
IT will be easier if you understand the functions of each, you need to seperate funtions in to (2) catagories. First is video - in order of best to worst is the following - Component, S-Video, and Composite (3 most common). Component is the Red,Green, and blue video wires, S-Video the the round plug with pins, and composite is the yellow single RCA jack. Sounds like you are discribing the Composite. Now sound (same order and most common) - Toslink, Coaxial, and analog. Toslink is fiber, coaxial looks like a single RCA port, analog is your red and white RCA's. Try to use the coaxial (a standard RCA cord will work) this will carry a true surround sound, as will the fiber. If you hook up analog (red and white) your reciever will have to 'fake' the surround sound- using DDPLII or DDPLIIx, etc. Most cheap DVD players dont have the digital RCA outputs for each speaker...but that sounds like that is what the 6 RCA's are for...not needed, just use the coaxial digital output. |
| Posted on Friday, January 21, 2005 - 12:18 pm: |
Thanks for your answer - ok lets see if i understand this: 1st of all let me tell you what's on the back of my DVD player; 2 main audio outputs (left & right), 1 component, 1 composite & 1 S-video output, 1 coaxial digital signal output and of course a scart which is linked to the TV. So, i should only use the coaxial digital to connect to the receiver - which input on the receiver do i hook it to? presumably all three? do i need an adapter then or a cable that has 3 x 3.5mm to 1 RCA (or coaxial)? Sorry for my lack of knowledge! |
| Posted on Saturday, January 22, 2005 - 05:32 am: |
Your receiver should have a dig coaxial port for the DVD input, just run one RCA from DVD to Receiver. The full surround is carried in this one cable. IF you use the receiver as a switcher then you would take (3) RCA's from component to component between the equipment, this will carry your video. |
| Posted on Sunday, January 23, 2005 - 07:37 am: |
Thanks again for your reply - unfortuneately my reciever doesn't have a digital coaxial port!? Am i screwed then? |
| Posted on Sunday, January 23, 2005 - 07:01 pm: |
Hey if you need some info check out my blog and near the bottom theres a surround sound step by step info thing. Hopefully this helps ssound12.blogspot.com |
| Posted on Monday, January 24, 2005 - 06:59 pm: |
does your receiver have any audio inputs other than analog (2 RCA ports) |
| Posted on Tuesday, January 25, 2005 - 10:00 am: |
My receiver has 3 audio inputs all analogue. |
| Posted on Wednesday, January 26, 2005 - 09:23 pm: |
Ya, sounds like your only option is to hook up the analog (red and white) and use DPIIx to 'reporduce' the surround sound. |
Post Number: 2604 Registered: Dec-03
| Posted on Thursday, January 27, 2005 - 09:23 am: |
Does it have a digital optical input?
| Posted on Monday, May 09, 2005 - 03:35 am: |
Hi I have Dapic hometheatre http://www.dapichongkong.com/hometer1.htm model D-600R & SANSUI 1221 DVD player . I Found MP3 CD's VCD plays well . Problem is that WHen i RUn DVD it not run well in PROLOGIC mode {DTS or DLOBY} it works fine only in Normal mode that is 2 spkr only. when i tried to run it in prologic mode , i can hear Music,drums , tribbles very well but not the dilogues. I belive cable connections are fine as it is as per diagrame. please sugest thanks ruturajpradhan@indiatimes.com |
Silver Member Username: Joe_c
Oakwood,
Ga
Post Number: 253 Registered: Mar-05
| Posted on Monday, May 09, 2005 - 08:00 am: |
wakey, basically you need a dvd player with built in dd decoding or one that has 5.1 output through rca's . other wise you will only get pl 2. rutuaj, your system seems to be ac-3 dts which is two channel only. Check users manual to see if any other settings must be made to get more than two channel reproduction. |
| Posted on Tuesday, July 19, 2005 - 10:53 pm: |
I have a new house with a built-in surround system with 6 speakers in the ceiling. Only one cable comes out of the wall for all the speakers. How do I hook this up? Does it go to the TV or to the receiver? |
