Thread: Any issues with uneven/long wiring lengths? |
Bronze Member Username: Bryanh
Fresno,
CA
Post Number: 19 Registered: Dec-04
| Posted on Thursday, January 20, 2005 - 03:06 am: |
Suppose one of my surround speakers has a 15-foot run, and the other one has a 28-foot run (have to go around a closet, it'll be easier to hide the cable going the long way around the room). Is this going to create problems with the surround speaker being 'in synch'? The speaker wire is 12-gauge, that should be enough for the long run I would think? |
Richard Andy Unregistered guest |
| Posted on Thursday, January 20, 2005 - 08:03 am: |
I doubt that there will be any noticeable difference. Some amps have options to add 'delay' to channels. I'd be worried if you were using different types of wire though.. |
Fresno,
CA
Post Number: 20 Registered: Dec-04
| Posted on Thursday, January 20, 2005 - 11:41 pm: |
It's all off the same loom, so that shouldn't be a problem. I don't remember reading about a delay adjustment for individual speakers in my Denon 2105 instructions, but it's a thick book so I could have forgotten it. Thanks. I'll get this room set up eventually. ;) |
| Posted on Friday, January 21, 2005 - 11:25 am: |
There is no reason to set a delay for a longer speaker wire. Delay settings are for differences in speaker distance, not wire length. The reason there might be an audible difference is if the speaker wire were a lot longer, increasing the resistance to the point that the power was reduced significantly, but this could be overcome by calibrating your setup. Also, using different types of wire shouldn't matter either. For instance, if you had a long run of wire to your surround speakers, you may consider using a thicker guage, but in your case, 12-guage is probably even overkill. |
