Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2005 > Help adding VCR to setup
Author Thread: Help adding VCR to setup
Username: Stevetracy
Hi I am trying to add a VCR to muy home theatre setup(as well as get my DVD player back up and running) and am not having any luck. The VCR (JVC HR-J692U) has only composite outputs on the back (and standard Coax input)
The system I am trying to add this to includes
RCA RT2370 HT Receiver
PRIMA TV with S-Video Component and Composite IN
XBOX (using Component IN on TV and Optical(switched) IN on Receiver
Motorola DCT2500 (Using Orange DigitalCoax on Receiver) and currently s-video for viewing
RCA 5 disk DVD player using optical (switched) IN on Receiver (Video is not currently hooked to anything(I;'m confused as to hwo this should work. I tried to hook it to the DVD IN on the Receiver but realized I was one s-video cable short so it is currently not hooked up.
How can I hook this situation up so I can watch my DVDs and also tape TV on my VCR. I can currently view VHS tapes but it is not hooked into the cable. All diagrams I have seen show inputs and outputs on the VCR.
HELP
Username: Dirtfarmer
Alberta
Post Number: 282
hello
try this site
Message Board: Home Theater: Home Theater Setup & Planning: The ultimate theatre setup guide
Use this link to go directly to the discussion:
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?3/113395
Thanks Dirt but that image doesnt really help. I can't read it or see it when I print it out. Thanks anyways though.
Alberta
Post Number: 339
i have e mail chart to people before
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2005 > Help adding VCR to setup [ « Previous ] [ Next » ]
