Thread: Problems using DTS |
New member Username: Ricardoht
Post Number: 3 Registered: Jan-05
| Posted on Sunday, January 16, 2005 - 12:01 pm: |
I recently bought an Onkyo HTS 770. Whenever I try to play DTS I hear no sound. Why is that? I can use Dolby Digital EX but no DTS. I loaded up Gangs of New York and it does have DTS track but I could hear no sound. Whenever I try to go to the 'audio adjust' in my receiver, I can only select Dolby, there is no DTS. With my DVD player I have the option of the following Digital Sound output: Dolby Digital/PCM PCM Stream Sample frequency: 48 KHz 96 Khz Which option should I choose? I'm new to this and I don't understand what PCM and those frequencies are for. Any help?
Post Number: 5 Registered: Jan-05
| Posted on Sunday, January 16, 2005 - 08:02 pm: |
anybody? |
Bronze Member Username: Rjw1138
Regina,
SK
Post Number: 11 Registered: Nov-04
| Posted on Monday, January 17, 2005 - 12:23 pm: |
I'm assuming you've got your DVD player hooked up to your receiver through a digital connection (coax or optical). You want to select the Stream option on your DVD player (the sample frequency shouldn't matter with Stream selected). This outputs the DD or DTS bitstream through the digital connection, to be decoded by your receiver. Workee?
Post Number: 8 Registered: Jan-05
| Posted on Tuesday, January 18, 2005 - 03:12 pm: |
I'll try that and I'll let you know tomorrow. |
New member Username: Jvc
NC
Post Number: 5 Registered: Oct-04
| Posted on Saturday, January 22, 2005 - 02:05 pm: |
Then you also HAVE to choose the dts track, in the movie's audio setup menu or Language menu. It doesn't automatically go to a dts soundtrack.  |
Regina,
SK
Post Number: 12 Registered: Nov-04
| Posted on Sunday, January 23, 2005 - 12:22 am: |
Natch! Of course I didn't mention this, but figured Ricardo would figure it out. He responded (to a different DTS related thread (!?)) saying he got it going. |
Bronze Member Username: Ricardoht
Post Number: 14 Registered: Jan-05
| Posted on Sunday, January 23, 2005 - 11:32 am: |
Yeah I got it going. I already knew I had to select DTS on the DVD menu, but thanks anyway guys. |
