Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2005 > Question about Composite cables and s...
Author Thread: Question about Composite cables and stuff (Newbie)
Username: Jeremybingham
Ok, Composite cables (Red, Blue, Green) only carry video correct?????
If so, what cables do I need to run audio signals from receivers, DVD, Satellite, etc????
Also, My satellite reciver has a square little hole that says Digital Audio out..... What is this?
Thanks.....again
Username: Rob24
the cabling that is supposed to go in a red blue green jacks is called COMPONENT cabling and yes component only carries video signals...
most likely the digital audio out is a toslink cable connection aka fiber optic connection...
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2005 > Question about Composite cables and s... [ « Previous ] [ Next » ]
