Thread: Need help picking surr. sound spkrs. and set up with Yamaha receiver |
New member Username: Rykoman
Mytown,
Ma
Usa
Post Number: 4 Registered: Dec-04
| Posted on Monday, January 10, 2005 - 06:13 pm: |
Have yamaha receiver 7.1 surround rxv2500 have one pair polk sda speakers about 15 years old-working great Also have one pair polk r 30s not hooked up Thinking of getting Polk PSW303 Black Powered Subwoofer and Polk RM6750 Six-piece, 5.1 Channel Home Theater Speaker System If I go for the above how should I hook up the R30's to my receiver? Would I in essence get 7.1 surround sound or should I buy 2 more satellite speakers and use the r30's up front with the SDAs. Any help would be appreciated as I don't know a lot about this stuff Thanks
Mytown,
Ma
Usa
Post Number: 5 Registered: Dec-04
| Posted on Monday, January 10, 2005 - 06:16 pm: |
Am I making a mistake with the polks? Want to spend about 500 but could probably go up to a 1,000 thanks |
Post Number: 2413 Registered: Dec-03
| Posted on Tuesday, January 11, 2005 - 08:11 am: |
Not a bad choice and I don't believe you are making any mistakes, but have you listened to other speaker systems, besides Polk?
Mytown,
Ma
Usa
Post Number: 6 Registered: Dec-04
| Posted on Tuesday, January 11, 2005 - 11:42 am: |
thinking of switching the subwoofer to Velodyne DPS-10 would that fit in? I'm hearing polk subwoofers aren't that great Thanks |
Post Number: 2425 Registered: Dec-03
| Posted on Tuesday, January 11, 2005 - 12:06 pm: |
I would do the same thing. Velodynes make great subs and are much better than Polks. |
