Thread: Need help with setting up 5.1 channel speakers |
New member Username: Realitygfx
UK
Post Number: 1 Registered: Dec-04
| Posted on Thursday, December 30, 2004 - 09:49 pm: |
well firstly, my knowledge of setting up audio systems, is low, very low i recently purchased with my birthday money some Philips 5.1 channel speakers, the trouble im having is actually connecting it to tv, laptop, etc. I have 3x 3.5mm jack cables which just tell me to connect them. I have absolutely no clue on how to connect this. All i know is that each 1 of them connects in the earphone bit lol. But with 3 wires n 1 port and no knowledge, i am completely stuck. This most probably is completely stupid but ive been looking and searching net for hours on end on my birthday looking on how to connect it but can find nothing.So i have come here to ask for some experienced help. In case i havnt explained clearly enough, Ive connected everything it says to the subwoofer, and im left with 5 speakers with a connection of 3x 3.5mm jack cables to which i only know fit into the earphone socket. With three of these wires and 1 port, i cant get my head around. Please reply as i have spent my whole birthday rackin my brains over this lol Many Thanks |
Post Number: 2283 Registered: Dec-03
| Posted on Thursday, December 30, 2004 - 11:29 pm: |
You need a receiver. |
UK
Post Number: 2 Registered: Dec-04
| Posted on Friday, December 31, 2004 - 06:56 am: |
can you give me anymore details for this? Thanks for your reply |
Post Number: 2288 Registered: Dec-03
| Posted on Friday, December 31, 2004 - 10:56 am: |
You need a receiver to be able to use these speakers. A receiver that is capable of using 5.1 speakers...a surround receiver, e.g., Kenwood KRF-9070d. |
UK
Post Number: 3 Registered: Dec-04
| Posted on Friday, December 31, 2004 - 12:11 pm: |
Thanks for reply, i ended up takin that back and bought a bush dvd player and 5.1 speakers together. Ive connected everythin that it says, ive done a speaker test on my dvd setup menu and everyone works, but when i actually want to listen to a CD or watch a DVD, only the left and right speakers work?, could you be of any help? |
Unregistered guest |
| Posted on Wednesday, January 26, 2005 - 11:41 pm: |
You have to adjust the program/stereo settings of your reciever, this should be in your manual, it is hard to tell without having your manual...honestly i just found this website cause i googled my name...Sean Scannell and found this lol. Anyways i'm a sound tech for the UW-Athletics and an EE...you just need to read your manual. feel free to e-mail me with any question...if you can't find the information in your manual i could probably look it up online...but it is better to figure these things out for yourself...you learn more . |
