Thread: Humming Noise (RECIEVER) |
New member Username: Morpheus2124
Post Number: 4 Registered: Dec-04
| Posted on Wednesday, December 29, 2004 - 12:05 pm: |
I just bought a KOSS KS5190 1000w surround sound system and i will pop in a dvd and about 3 times during a two hour movie i will hear a humming noise coming from the actual Reciever (not speakers). It is very noticeable. It sounds like a vibrating cell phone sitting on a piece of wood. Really weird. What does that mean?? Is this piece defective. |
Post Number: 2263 Registered: Dec-03
| Posted on Wednesday, December 29, 2004 - 12:26 pm: |
A humming receiver is never normal unless it doubles as a cell phone or pager. Return it. |
gieopnpe Unregistered guest |
| Posted on Monday, January 17, 2005 - 12:37 am: |
hey have you herd the koss 1000w KS5190 sound system? is it good?
Post Number: 2477 Registered: Dec-03
| Posted on Monday, January 17, 2005 - 10:02 am: |
no, no and no. What does this have to do with this thread? |
New member Username: Canuckinapickle
Toronto Canada
Post Number: 5 Registered: Jan-05
| Posted on Tuesday, January 18, 2005 - 05:58 pm: |
Peter, Does this receiver have an internal fan of some sort? If it does you may have a bad fan which is causing the hum -- much like the fan on a computer's CPU if it gets old or is defective. Just a guess though, I don't know that product at all. |
Bronze Member Username: Mystro
Post Number: 12 Registered: Jan-05
| Posted on Thursday, January 20, 2005 - 07:47 pm: |
Change your amps polarity and power source. One of your other gear might not be grounded. Put your Amp on its own power source and see if the humming changes or stops. |
Dan Herron Unregistered guest |
| Posted on Tuesday, February 08, 2005 - 09:28 pm: |
Having the same problem here except it starts humming as soon as I turn it on and it's brand new!! I took so long to hook it up the 30 day return policy has expired and now I have to pay to ship it to Missiouri!!! |
| Posted on Saturday, February 12, 2005 - 06:46 pm: |
Having exactly the same problem with mine. As soon as I turn it on it makes a loud humming, like the fan is bad or the bearings in it are out. Then after about 10 minutes it stops and works fine. Have had it for 6 weeks. |
New member Username: Nullsmurf
Denver
Post Number: 1 Registered: Feb-05
| Posted on Sunday, February 13, 2005 - 11:56 am: |
strange that there are so many that hum out of the box. Yes, I quickly identified it as a humming fan - there appear to be 2 on the right side. A couple of finger thumps got the fan spinning and I haven't heard it since. However, there seems to be a GREAT deal of heat buildup. Make sure yours is VERY well ventalated. It would be different if I were pushing it, but I'm not. I'm inclined to let the unit toast itself. |
New member Username: Jamesca
Post Number: 2 Registered: Feb-05
| Posted on Saturday, February 19, 2005 - 01:23 am: |
Take your reciever in for a servic check up somethng is wrong !! or if it's fairly new ask for a new replacement instead . James.ca |
Post Number: 3 Registered: Feb-05
| Posted on Saturday, February 19, 2005 - 01:31 am: |
Note your amp has to have some air space around it to let the heat out !! The heat sinks have to have some where to let the heat go !! Don't stack other gear on your amp !! Have the shelf it's on have some openenss to it as well. I rack mounted my surround amp , nothing on top nothing underneth either and space on the sides as well. Amps run hot and get hotter when pushed but at the same time have to let the heat out of the unit or your going bust your baby !! James |
| Posted on Wednesday, March 16, 2005 - 10:11 am: |
Can't believe what I'm reading. Mine is doing the same thing. Loud noise from fan goes away in about 20 sec. or after thump. unit only 2.5 months old. Called Koss, will only do refund. But I'm completly wired in! Help!! |
| Posted on Wednesday, March 16, 2005 - 10:12 am: |
Denver
| Posted on Wednesday, March 16, 2005 - 09:27 pm: |
Not to worry, Bob. Its designed to run hot, or better be. Besides, it was cheap! I decided that it fries, or it doesn't. So far, it has not. Also, the fan noise quit after a few dozen operating hours. I figure that if Koss burns my house down, I get to retire. |
gator bob Unregistered guest |
| Posted on Thursday, March 17, 2005 - 03:02 pm: |
Spoke to Koss (India) again yesterday, They still want to refund me. They claim they don't have any to replace mine with, yet Best Buy down the road has 20 in stock. The problem is they have gone up in price $60. since December. So a refund won't cover the cost of a new one. The warranty states "repair or replace" not go buy a new one at their new price. |
| Posted on Saturday, March 19, 2005 - 07:06 am: |
Still no response from Koss on my KS5190 problem. I moved the unit to a better ventilated location. I noticed the unit has 2 fans. Only the front fan runs. Can you tell me if both of your fans run when the unit is on or is the rear fan on some type of switch? |
Koss Victim Unregistered guest |
| Posted on Monday, March 21, 2005 - 07:04 pm: |
I brought the same system (Koss KS5190) and had the same problem only it got worse. There was a breif period of on and off grinding noises inside the main unit. This eventually led to a constant grinding noise. I sent the unit back, but I had to pay shipping and they shorted me $10 when I got the refund check. I wish I had two more hands so I could give Koss a four thumbs down.... |
AndyChicago Unregistered guest |
| Posted on Tuesday, March 22, 2005 - 03:39 pm: |
I have experienced the same exact thing - and I'm glad I read this thread, because I was going to just go out and buy a new one, figuring it was just my unit and not a larger problem. I'm sending mine back in for a refund...UGH. |
Yipperz Unregistered guest |
| Posted on Monday, March 28, 2005 - 11:34 pm: |
I am in the same situation, and it's the back fan on the right side that doesn't work for me either. I'm guessing the system has a faulty fan put in there. I'm just gonna buy a replacement fan. They can't be very expensive. |
