Thread: Wall Plates for A/V Signals DVI etc.??? |
Unregistered guest |
| Posted on Tuesday, December 28, 2004 - 04:23 pm: |
Hello, Are decorative wall plates availabe for A/V signals, (DVI/HDMI)??? Here's my plan, I am moutning 37" Plasma display from the ceiling. Would like to have DVD and HDTV Cable Box in the corner on a stand. Run cables thru the wall, hence the wall plate connector need. Suggestions welcome. Thanks Dan |
| Posted on Tuesday, January 11, 2005 - 02:33 am: |
Hey Dan. I had the same problem! the mthr fu**rs at radio shack and bestbuy etc. tried to sell me stuff that i did not need! they said they DO make them but they are way to much $$ all I did was buy the plugs and made the plate myself outa aluminuim! GOOD LUCK |
Bronze Member Username: Philman
Richmond,
IN
Post Number: 57 Registered: Dec-04
| Posted on Tuesday, January 11, 2005 - 09:04 pm: |
I agree they're pricey, but hey, its HD we're talking about. If you've spent the $$ to get this far whats a few more. eh? Check out this link, for the DIY'er http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=251 |
