Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through May 02, 2005 > Help on Speakers ?
Author Thread: Help on Speakers ?
jboyle
I just bought YAMAHA RX-V1500 reciever. For speakers , I have fianlised to "Paradigm" and budget is $2K. Right now I am panning to buy Monitor 5 Series, Center CC-370, Sub PDR12, and surround ADP-370. Any advise? or recommedation on speakers ? Thanks
Username: Project6
Post Number: 2220
Looks like you are on the right track!
infinity2
I need speaker advice too .. but with older kappa 9 being bi-amped with yamaha M80 and yamaha M65. Problem is low isn't impressing me as my RS II have more thump ... heck my TV probably have more thump. What is the trick to tweeking the kappa base?
Username: Gavincumm
Post Number: 20
Bi amp with the same type of amp, and not use two different amps to do it. that's the trick.
gavin
Greg W
Find someone who sell RBH speakers You will be glad you did.
Username: Gavincumm
Post Number: 76
this guy is pushing RBH because he is an RBH dealer. He admitted it in a post below this one. Of course he is going to love the way they sound.
Listen with your own ears and no one elses.
gavin
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through May 02, 2005 > Help on Speakers ? [ « Previous ] [ Next » ]
