Thread: Matching Infinity |
New member Username: Richieh
Post Number: 2 Registered: Dec-04
| Posted on Friday, December 17, 2004 - 06:26 pm: |
I have a set of Infinity Overature II's that I would like to incorporate into my home theater system (front speakers) and an infinity center channel as well. Which would be the best speakers to match to create a 7.1 system. How about Receiver to drive the overaturs (they have powered front/rear throw subwoofers). They sound really good eventhough I've had them about 10 years. THANKS! Rich |
Post Number: 2134 Registered: Dec-03
| Posted on Monday, December 20, 2004 - 08:47 am: |
What is your budget? The overtures are fine speakers...any chance of getting your hands on the Intermezzo?
Post Number: 3 Registered: Dec-04
| Posted on Monday, December 20, 2004 - 07:50 pm: |
Berny, I really don't have a budget, but I do like value. I was hoping to pair the infinitys up with some good surround speakers and a good receiver. That said, I would like to spend somewhere near 1K on surrounds and a sub. Any advice is greatly appreciated! How about a DENON Receiver to power the overatures? How would Paradigm match the infinitys? THANKS! Rich |
Post Number: 2157 Registered: Dec-03
| Posted on Tuesday, December 21, 2004 - 09:10 am: |
Denon is a great receiver to drive the Overtures. Have you considered using Infinitys for your surrounds? |
Post Number: 4 Registered: Dec-04
| Posted on Tuesday, December 21, 2004 - 07:38 pm: |
Berny, Yes, I considered the Infinity's & Paradigm as surrounds; next is to give them a listen. I have a good Infinity center channel that I plan to use as well. Is there a particular Infinity model that would make a good surround, and 6.1 speaker? I'm considering the Dennon 2805 as a receiver. Thanks for the help! Rich |
