Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 23, 2004 > Newbie - How to connect sub woofer
Author Thread: Newbie - How to connect sub woofer
Username: Sunseaker
Forgive me if this is a real lame question but I am totally new to HT. I am researching getting a HT set-up and have noticed some AV amps have a sub woofer speaker connection and some don't.
Where do you connect the sub if there is no sub woofer connection?
Username: Pbar
It can't be a 5.1 or 6.1 without the sub output
Username: Sunseaker
Thanks. I just figured it out. The subs are active so they only need a feed from the output as opposed to a speaker output. I did say it was a dumb question.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 23, 2004 > Newbie - How to connect sub woofer [ « Previous ] [ Next » ]
