Thread: Help with HK AVR525 and video connections and other ?? |
New member Username: Dougg
Atlanta,
GA
Post Number: 6 Registered: Apr-04
| Posted on Saturday, December 11, 2004 - 04:03 pm: |
I have a HK AVR525 that is connected as follows: TV: S video from HK to S video in on TV Audio out from TV L/R to Video 2 Audio In on HK CD: Coax digital out to Coax digital In on HK VCR: Video Out to Video 1 Input on HK Video In to Video 1 Output on HK R/L Audio output to Video 1 Audio Input on HK R/L Audio Input to Video 1 Audio Out on HK DVD S Video out to DVD Video In on HK Digital Optical Out to Optical Dig Audio In on HK On the analog inputs (TV and VCR) I have them set to Dolby Pro Logic II. Question: Is this the best setting or would Logic 7 be better (or any of the other choices) On the digital input of the DVD, I have set to Dolby Digital. Question: Again, is this the best choice? When using DVD or VCR, I can hear the sound but not see any picture. Question: What do I have set up wrong? Do I need to go S video right from the DVD to the TV and bypass the HK? Do I need to run composite cables straight from the VCR to the TV and bypass the HK? If I do both of the above, I will have no direct input from the HK to the TV (TV only has one S Video and one Video in, but no component) and will lose the ability for On Screen directions? Last question: I have the following speakers Front: Dahlquist DQM9, 35Hz - 22kHz Surround: Dahlquist QX6A, 37Hz - 20kHz Center: Dahlquist QX50C, 55Hz - 20kHz Sub: Dahlquist PDQ1200, 30Hz - 150Hz I have my speakers set to Large for the fronts and small everywhere else. I have the crossover set for 80Hz on all speakers. Does this sound right or should I have them set differently? Thanks very much for any help to this newcomer to home theatre. Doug
Atlanta,
GA
Post Number: 7 Registered: Apr-04
| Posted on Sunday, December 12, 2004 - 08:33 pm: |
Help? Anybody??? |
