Thread: COMPONENT CABLE |
New member Username: Boca
Post Number: 2 Registered: 01-2004
| Posted on Saturday, January 31, 2004 - 10:33 am: |
I would like ih someone can clearify for me the use of COMPONENT cables in this case as below. I can definitly use COMPONENTS from my DVD to my AVR DENON. However my TV has S conector as the best vidoe oprion. So is there any relevance if I run DVD to AVR with COMPONENT cables. Do I gaing anithing here or S should follow S |
Bronze Member Username: Emkmd
Post Number: 25 Registered: 12-2003
| Posted on Sunday, February 01, 2004 - 11:23 am: |
You should not gain anything. Consider running the DVD directly into the TV. The downside of this is having to switch both the receiver and the TV to the DVD input, instead of letting the receiver making all of the switches. -E |
Germain. Unregistered guest |
| Posted on Tuesday, February 24, 2004 - 05:32 pm: |
Hi everybody. I have a question that is somehow similar to the one posted by the user Boca. I have a DVD player with COMPONENT, RGB-ready scart and S-Video outputs. But my TV has got RGB scart and S-video scart inputs. What kind of connector should I use to get the best possible image? COMPONENT to RGB scart? or RGB to RGB? Thank you. |
Silver Member Username: Project6
Post Number: 295 Registered: 12-2003
| Posted on Tuesday, February 24, 2004 - 08:19 pm: |
RGB to RGB |
