Thread: Polk Audio RM6900 |
| Posted on Wednesday, December 01, 2004 - 10:40 am: |
I am considering the polk audio RM6900 for 70% music 30% movies. Are there any reviews on this speaker system? Any thoughts on which receiver (considering Yamaha, Denon and Harmom Kardon) would work best with the RM6900 would be appreciated.
BuffaloAdam Unregistered guest |
| Posted on Tuesday, January 04, 2005 - 03:23 pm: |
I just bought them and am going to hook them up tonight. I also bought the Yamaha RX-V650 receiver. I'll let you know in a few days how they worked out. I've listened to them at two different stores and they sounded great. All reviews I've read, only a few though, have been good. Since they're new there isn't many reviews out yet.
Bronze Member Username: Duckwing
Post Number: 14 Registered: Dec-04
| Posted on Tuesday, January 04, 2005 - 04:43 pm: |
I have the RM20, which is basically the same system, sounds great on a Onkyo 502, using LFE cable for my sub. |
George Lee Unregistered guest |
| Posted on Thursday, January 06, 2005 - 09:25 pm: |
I bought the same package as Adam less than a month ago, i.e. Polk Audio RM6900 + Yamaha RX-650. I like the system very much. Both the music and home theatre sounds wonderful. I also found that there is not so many reviews about RM 6900 yet. |
