Thread: Better wires, better sound? |
Unregistered guest |
| Posted on Tuesday, November 30, 2004 - 07:14 pm: |
Help, I currently use a Sony DAV-C450 and I just use the regular speaker wire that came out of the box. I am wondering if upgrading it will really improve the sound. I also need some advice if the: Monster HTIB CV Component Audio/Video Kit is any good, cause I could use basically all that comes with it.
Bronze Member Username: Scotty2hotty
Chicago,
IL
Post Number: 12 Registered: Nov-04
| Posted on Tuesday, November 30, 2004 - 09:32 pm: |
For that system, I wouldn't waste the money on the wiring. |
Post Number: 1948 Registered: Dec-03
| Posted on Wednesday, December 01, 2004 - 08:25 am: |
uh-oh, hot topic... anyway, check out the cable connections from Acoustic Research, good quality construction and reasonable priced. For speaker wires, just get yourself a 14 gauge wire. |
BenKentari Unregistered guest |
| Posted on Wednesday, December 01, 2004 - 06:01 pm: |
So would the sound improve with better wires, even if this isnt the best system. And is that monster set (Monster HTIB CV Component Audio/Video Kit) worth it? |
Post Number: 1960 Registered: Dec-03
| Posted on Wednesday, December 01, 2004 - 06:40 pm: |
The Monster set is not worth it. Try out better cables andsee for yourself. if you don't heat a difference or improvement, return them. |
| Posted on Thursday, December 02, 2004 - 06:16 pm: |
Thanks for the help. Just one last question. What guage would you recomend for that system.(if you even know it)And im still feeling that monster set.. |
Post Number: 1974 Registered: Dec-03
| Posted on Thursday, December 02, 2004 - 11:51 pm: |
it is always good to use at least 14 gauge wire for speakers. if you are feeling the Monster set just get them, what is stopping you |
| Posted on Friday, December 03, 2004 - 02:13 pm: |
lol nothing stopping me I guess. But the price of the monster doesnt matter. Will the quality of sound be better with it? And by some chance do you know the guage of that set? Thanks. So much for last question. lol |
Post Number: 1993 Registered: Dec-03
| Posted on Monday, December 06, 2004 - 09:42 am: |
You will be the ultimate judge of any sound improvement. Some people experience it and some don't. |
| Posted on Monday, December 06, 2004 - 06:47 pm: |
Lol... Too bad I cant refund it |
Post Number: 1996 Registered: Dec-03
| Posted on Monday, December 06, 2004 - 08:28 pm: |
If you like them, who cares?! Right? That's what i tell people, so you're doing good as long as YOU like it!
| Posted on Wednesday, December 08, 2004 - 09:31 pm: |
but i dont know if i like it cause i havent heard it yet... |
