Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 23, 2004 > Speakers for Yamaha RX-V1500 ?
Author Thread: Speakers for Yamaha RX-V1500 ?
Username: Musicjb
I just bought "Yamaha RX-V1500" receiver. Please recommend me for a good speaker system. Should I consider buying a Infinity/JBL/HK/Polk system ? Thanks.
All those are pretty good systems. I would also consider Klipsch.
Username: Project6
Post Number: 2009
Try Paradigm or Axiom.
Any budget?
Username: Elitefan1
Post Number: 963
John,
You have bought a very nice mid priced receiver and I second the choice of Paradigm but not Klipsch. Over the years I have found no better speaker for Yamaha's than Paradigm and that holds even though Yamaha's are no longer overly bright as in the past. Check out the Paradigm Monitor series and you'll many great match's for your Yamaha. PSB also is a good choice.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 23, 2004 > Speakers for Yamaha RX-V1500 ? [ « Previous ] [ Next » ]
