Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2005 > Choosing 7.1 receiver
Author Thread: Choosing 7.1 receiver
Username: Fotek
Hi. I'm buying my first receiver. No speakers yet but i'm planning to buy Audes Blues or something similar to front.
Whitch one of those would you recommend?
Besides movies, I'm interested in very good stereo performance also.
Which receiver is most musical and which is least?
Onkyo TX-SR602E
$389-$499
http://www.onkyo.net/uk/cms/products/home/av_rec/TX-SR602E/
Marantz SR4500
http://www.marantz.com/new/index.cfm?fuseaction=Products.Product&cont=eu&bus=hf& prod_id=3201&series=comp&type=avr
Denon AVR-1905
$344-$499
http://www.denon.de/site/frames_main.php?main=prod&ver=&MID=3&sub=1&action=detai l&Pid=147
Yamaha RX-V650
$334-$347
http://www.yamaha-online.de/products.php?lang=e&idcat1=1&idcat2=2&idcat3=2&idpro d=1103&archivset=&newsset=
any other recommendations are welcome also!
Username: Project6
Post Number: 1829
Marantz SR4500, great performer and nicely musical.
Username: Elitefan1
Post Number: 877
Check out the Marantz 5400 at hifi.com at $449.
I'm in the exact same situation and price range for a receiver. I'm hoping to find something on black fri.
I'm leaning towards the Denon AVR-1905.
Username: Fotek
I bought Denon 1905, works nicely.
only problem it that the remote may not work with all your other equipment - it's not a learning type.
dingo
recieved onkyo sr702, very nice, using with JBL northridge 7.1, thx is unbelievable.
Username: Bryanh
Fresno, CA
Post Number: 9
I'm a bit lost too. Trying to decide between the Denon 2105, Marantz 4500, and Harman/Kardon 335.
There are so many options out there and so many features that each unit touts, it's overwhelming!
I plan to use my receiver for DVD, DVD-Audio, and CDs about equally.
Username: Bryanh
Fresno, CA
Post Number: 10
Whoops, hit the button too soon.
It may come down to a battle of features for me if the sound quality of these three are on even footing, I suppose. For example the Denon has a memory system that remembers the mode for each input. I think that would be helpful. The HK has individual crossovers for the front 3 speakers which I would imagine is an aid in tuning the sound correctly. The Marantz doesn't seem to have either of these (and no crossover adjustment at all that I could find) but a reputation for being musical.
Argh! I want it all but I can't have it...
Username: Fotek
the Denon also automatically detects incoming signal type.
for example i have DVD player connected via coaxial and it automatically switches between stereo and dolby digital, if i take out a CD and insert a DVD
Username: Sunseaker
asd asd, I am considering the Onkyo 602 and Yamaha 650. Any reason why you dodn't go for either of these and chose the Denon?
zero1
I bought MARANTZ 4500 a few days ago.
It's very nice receiver, good looking and very impressive sound both from cd music and HT DVD.
Nonthaburi
THAILAND
adam1111
I need help with choosing a receiver, 75% home theater and 25% music, I was looking at the Yamaha v550 or the 5760. I was also looking at Klipsch synergy speakers. Is this a good match or is there a better receiver for Klipsch speakers or better speakers for under $1000?
Username: Yamahapaiste
Niskayuna, Ny
Usa
the question is how much do you want to spend? I am looking at the cost benefit ratio myslef, and at the price points that the other responders have mentioned I would reccomend the Yamaha RX-V 750.
Crunchy
I bought a Sony STR-DB790. Nice reciever. About AU$800 worth. Dunno where you are, but in England or US probably a lot less.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2005 > Choosing 7.1 receiver [ « Previous ] [ Next » ]
