Thread: Advice needed to complete my Paradigm system |
New member Username: Pass
Post Number: 1 Registered: 01-2004
| Posted on Tuesday, January 27, 2004 - 12:26 pm: |
Hi all, just wanted to get some opinions from some true audiophiles. I'll admit I don't know what i'm doing right off the bat, so I could really use some advice. I'm looking to add to my home theater system, right now I have: Paradigm Titans (front), PS1000 sub, Denon AVR-2800 receiver, crappy surround speakers. What do you guys suggest I buy to complete the system? Right now I am thinking of getting a CC-170 center speaker and either getting a set of Paradigm towers and using the titans as surrounds, or just keeping the titans up front and getting some Paradigm surrounds. Would a set of towers sound that much better than the Titans in this case, and if they are, which would you suggest? If not, which Paradigm surrounds would you suggest? I will spend the money if I have to, but if its not going to be a big difference then I would rather spend my money elsewhere. Your thoughts would be greatly appreciated!
