Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through January 12, 2005 > Looking for speakers
Author Thread: Looking for speakers
Username: Vader76
Its been awhile since I've gotten new speakers but I"m ready for some new ones. I"m not sure exactly what to look for in new speakers.
I have a Pioneer VSX-D409 as my receiver. I'm looking to spend between $1000-1500 for a new set of 5.1 speakers. Any recommendations on what I can get?
Thanks...
Username: Project6
Post Number: 1825
check these out
http://www.axiomaudio.com/epicmaster.html
or you can also go with ascend acoustics with hsu subwoofer
Epic
How big is your room? What size speakers are you looking for? You could get a Mod2 system from Orb Audio (http://www.orbaudio.com) or the Axiom speakers recommended above (http://www.axiomaudio.com). I really like the value delivered by the online guys.
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through January 12, 2005 > Looking for speakers [ « Previous ] [ Next » ]
