Thread: Do I need these wires hooked up? |
New member Username: Joshbwatkins
Post Number: 2 Registered: 01-2004
| Posted on Tuesday, January 27, 2004 - 02:33 am: |
Hey guys, My dvd player recommends that besides having either the coax or optical hooked up to my reciever for sound, and that I should also hook up the plain ole' rca's as well but gives no reason? any idea why, and do I really need to do this? Thanks, Josh |
New member Username: Project6
Post Number: 155 Registered: 12-2003
| Posted on Tuesday, January 27, 2004 - 06:08 am: |
for analog stereo sound |
New member Username: Hampshire
Post Number: 8 Registered: 12-2003
| Posted on Tuesday, January 27, 2004 - 12:53 pm: |
No, you don't need to do this. Even if the dvd is analog stereo, the player will use the optical line to send the signal to the receiver. |
Post Number: 160 Registered: 12-2003
| Posted on Tuesday, January 27, 2004 - 01:12 pm: |
hmm, good point, come to think of it, I don't have stereo analog hooked up from my dvd player and it still plays is stereo mode |
Post Number: 3 Registered: 01-2004
| Posted on Tuesday, January 27, 2004 - 05:06 pm: |
on the topic of cables would a thicker coax cable from my subwoofer to my reciever help out, it came with a dinky thin little thing, wondering if it would make a difference to upgrade a little bit, granted I don't want to spend 30 dollars on a monster cable as I'm not that "audiophile" crazy..but I do like a nice system for the funds available. |
Post Number: 161 Registered: 12-2003
| Posted on Tuesday, January 27, 2004 - 05:29 pm: |
you can start here...excellent cables at a great price...did that sound like a commercial?? cheers http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=59 |
Post Number: 4 Registered: 01-2004
| Posted on Tuesday, January 27, 2004 - 06:34 pm: |
Thanks Berny... Can anyone give me a recommendation on a subwoofer in the 200 dollar range? I live in a 12x12 dorm room, so spending more than that is overkill.. I was looking at these at a quick glance... http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3073700290&category=3275 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3074623692&category=3275 anyone suggest anything better in that price range..or if they think that one of these will be good.. |
