Thread: No digital Input Samsung DS610 |
New member Username: Jtsultim
Post Number: 1 Registered: Nov-04
| Posted on Sunday, November 07, 2004 - 09:57 am: |
I have a samsung DS610 I also have a phillips tivo direct TV DVR. My phillips has a digital output, my samsung has two digital inputs. I have a monster cable digital cable. Once connected I change my samsung input to digital 1 (where I have my phillips output plugged into) it searches for a siganl then stops and no sound is played. I have a signal (I believe) comming from my phillips (red light at end of cable). I have tried both digital inputs on the samsung with the same results. I am frustrated and could use some advice. Thanks in advance, J. |
Post Number: 1793 Registered: Dec-03
| Posted on Monday, November 08, 2004 - 07:10 am: |
Have you set up the Philips to output digital signals? Go to the setup menu and audio output. You should have choices of stereo, digital, etc. |
Post Number: 2 Registered: Nov-04
| Posted on Monday, November 08, 2004 - 07:57 am: |
Yes that has been done. |
Post Number: 3 Registered: Nov-04
| Posted on Tuesday, November 09, 2004 - 06:58 am: |
Got it to work |
