Thread: Harmon Kardon or Dennon |
New member Username: Vikram
Mumbai India
Post Number: 1 Registered: Nov-04
| Posted on Friday, November 05, 2004 - 03:35 am: |
Hi I have been looking at AVR's for the last 1 year and in the country that i live thats india we have limited choice on amps. Its denon, Marantz, HK,Onkyo,Yahama. Now i am really confused which one to buy HK AV130 or Denon 1604/1804. I have heard the system like in the following combinations 1> Denon + Whardele 8.4 diamond - Did not like 2> Denon + Jamo (E580) - sounds ok 3> Yahama + wharfadele - Sad 4> HK + Jbl E80 seris- Believe me this sounds like superb and i can swear on it. Now can anyone advise me with the limted choices that i have put above is HK amp better or Dennon AMP better with Jbl E 80 series. Actually to be frank i am getting a Denon 1804 at the cost of Harmon Kardon AVR 130. Is HK 130 worth a buy as compared to denon 1804????
Bronze Member Username: Pal
Pune India
Post Number: 54 Registered: Apr-04
| Posted on Saturday, November 06, 2004 - 03:21 pm: |
hi you can get NAD/PSB too...better check that out too... infact NAD goes equally well with PSB and B&W. and u get all that in mumbai itself.. and frankly i found PSB and B&W much better sounding speakers than JBL, but then follow what suits your ears the best !! |
New member Username: Kalamandir
| Posted on Monday, November 22, 2004 - 05:25 pm: |
For AVR noithing beats the Harmon Kardon series. It has DTS, DTS-Neo, DD with a 7 channel output of 100W in each channel and a low THD. For speakers I recommend Bang & Olufsen (get them from S'pore if you can, worth it) or Cambridge Sound and lastly Bose (not a huge fan but thy are OK). An alternate solution is to build a HTS using your desktop computer, here is the list: 1. A Desktop Computer with a Pentium processor (3.2) with Hyper-Thread Technology (HT will allow you to listen to music and browse the web wihout any slow down) 2. A ATI TV-Video Tuner card (connecting this to your cable will allow you to watch TV, record TV shows/movies on your hard drive and later burn them on DVD's) 3. A dual layer DVD burner (both Sony & Pioneer are good and you can get either one for $80 to $100) 4. Sound blaster Audigy Platinum 2 sound card (7.1 Dolby Digital and has DTS encoding as well) 5. A 26-30" LCD or a 1024 X 768 resolution DLP projector (better if it comes with a interlacer such as Faroudja) - You can get a Dell or a Sharp projector one for $1000. The LCD's are better off buying from Singapore since even after paying customs (usually you can get away by giving Rs50K) they still come out cheaper. Lastly a low cost option is to get one of those HT in a box systems. Recommend Panasonic SCT700, comes with a 5 disc DVD player and a reciever and 5 satellite speakers and a subwoofer. Still need a display such as a LCD or a DLP projector if you plan to watch DVD's, play games |
